Vinchin supports agentless backup for Sangfor HCI and Sangfor SCP and you can use the backup to restore Sangfor VM or perform V2V migration.
Vinchin supports agentless backup for Sangfor SCP and Sangfor HCI backup. You can directly add Sangfor SCP cluster controller to Vinchin but you need to install a plugin on the Sangfor HCI host before adding it
Then you can add the Sangfor host with its credentials.
Backup Sangfor VM:
After adding the Sangfor host, you can create a backup task in 4 steps.
- Select the Sangfor VMs you want to backup.
Restore Sangfor VM:
When you need to restore an Sangfor VM, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from Sangfor backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it or instant restore to quickly restart a failed VM.
