Vinchin supports agentless backup for H3C CAS/UIS and you can use the backup to restore H3C VM or perform V2V migration.
Before adding the host, you need to install a plugin on the H3C host.
Then you can add the H3C host with its credentials.
Backup H3C VM:
After adding the H3C host, you can create a backup task in 4 steps.
- Select the H3C VMs you want to backup.
Restore H3C VM:
When you need to restore a H3C VM, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from H3C backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it or instant restore to quickly restart a failed VM.
If you still have questions after referring to our documentations and videos, please start a thread in this section or contact our technical support team at technical.support@vinchin.com for assistance.
