Vinchin supports agentless backup for Huawei FusionCompute and you can use the backup to restore the VM or perform V2V migration.
You can add the Huawei FusionCompute host with its credentials.
Backup Huawei FusionCompute VM:
After adding the Huawei FusionCompute host, you can create a backup task in 4 steps.
- Select the Huawei FusionCompute VMs you want to backup.
Restore Huawei FusionCompute VM:
When you need to restore a Huawei FusionCompute VM, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from Huawei FusionCompute backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it or instant restore to quickly restart a failed VM.
If you still have questions after referring to our documentations and videos, please start a thread in this section or contact our technical support team at technical.support@vinchin.com for assistance.
