Environment
MySQL
Error Message
Instance Authentication failed, error code: #300059, error description: connect to mysql server failed
Cause
The database information may be entered incorrectly or the user does not have the remote access permission.
Resolution
- Make sure that MySQL is running and that you have entered the correct database configuration file path(my.cnf), user name or password.
- You need to check the user name used during the addition to authorize remote access. You are advised to let the database administrator perform this operation.
