Vinchin Backup & Recovery provides agentless volume-level backups of Huawei ECS.
Before creating a backup job, you need to first connect the Huawei cloud platform to Vinchin.
Backup ECS Instance:
After adding the Huawei cloud platform, you can create a backup job in 4 steps.
- Select the ECS instance you want to backup.
- Select backup storage.
- Configure backup strategies.
- Submit the job.
Restore ECS Instance:
When you need to restore a ECS instance, just select the restore point in the system and create a restore job in 4 steps.
- Select a target ECS Instance restore point under the Huawei cloud platform.
- Select a target cloud platform you wish to run the restored Instances.
- Configure strategies or just skip it
In addition to restore fully functional ECS instances by using the in-cloud snapshot or off-cloud backup data, you can also use it to perform granular restore to quickly extract file from it.
If you still have questions after referring to our documentations and videos, please start a thread in this section or contact our technical support team at technical.support@vinchin.com for assistance.
