Vinchin Backup & Recovery provide agentless S3 backup for multiple object storage vendors.
Before creating a S3 backup job, you need to first add the Object Storage to Vinchin Backup & Recovery and get the object storage licensed for backup. Please refer to Object Storage for more information.
Create S3 Backup Job:
After configuration, you can create a backup task in 4 steps.
- Select a target Object Storage for this backup job.
- Select a backup node and target storage.
- Configure backup strategies.
- Submit the job.
S3 Restore:
When you need to restore files from S3 backup, just select the restore point in the system and create a restore job in 4 steps.
- Select the target object storage and a desired restore point.
- Specify the destination for the selected files/folders to be restored to File Server,NAS Server or Object Storage.
- Configure strategies or just skip it
If you still have questions after referring to our documentations and videos, please start a thread in this section or contact our technical support team at technical.support@vinchin.com for assistance.
