Vinchin supports agentless backup for oVirt VM and you can use the backup to restore oVirt VM or perform V2V migration.
Before adding the host, you need to install a plugin on the oVirt host.
Then you can add the oVirt host with its credentials.
Backup oVirt VM:
After adding the oVirt host, you can create a backup task in 4 steps.
- Select the oVirt VMs you want to backup
- Choose backup storage
- Set the backup policy
- Submit the task
Restore oVirt VM:
When you need to restore a oVirt VM, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from oVirt backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it or instant restore to quickly recover a failed VM.
For the detailed steps, you can refer to this video:
If you still have questions after referring to our documentations and videos, please start a thread in this section or contact our technical support team at technical.support@vinchin.com for assistance.
