Vinchin supports agentless backup for OLVM VM and you can use the backup to restore OLVM VM or perform V2V migration.
Before adding the host, you need to install a plugin on the OLVM host.
Then you can add the OLVM host with its credentials.
Backup OLVM VM:
After adding the OLVM host, you can create a backup task in 4 steps.
- Select the OLVM VMs you want to backup
- Choose backup storage
- Set the backup policy
- Submit the task
Restore OLVM VM:
When you need to restore an OLVM VM, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from OLVM backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it or instant restore to quickly recover a failed VM.
For the detailed steps, you can refer to this video:
