Vinchin supports agentless backup for RHV VM and you can use the backup to restore RHV VM or perform V2V migration.
Before adding the host, you need to install a plugin on the RHV host.
Then you can add the RHV host with its credentials.
Backup RHV VM:
After adding the RHV host, you can create a backup task in 4 steps.
- Select the RHV VMs you want to backup
- Choose backup storage
- Set the backup policy
- Submit the task
Restore RHV VM:
When you need to restore a RHV VM, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from RHV backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it or instant restore to quickly recover a failed VM.
For the detailed steps, you can refer to this video:
