Vinchin supports agentless backup for Citrix Hypervisor VM and you can use the backup to restore Citrix Hypervisor VM or perform V2V migration.
Before adding the host, you need to install a plugin on the Citrix Hypervisor host.
Then you can add the Citrix Hypervisor host with its credentials.
Backup Citrix Hypervisor VM:
After adding the Citrix Hypervisor host, you can create a backup task in 4 steps.
- Select the Citrix Hypervisor VMs you want to backup.
Restore Citrix Hypervisor VM:
When you need to restore a Citrix Hypervisor VM, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from Citrix Hypervisor backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it or instant restore to quickly recover a failed VM.
