Vinchin supports agentless backup for XCP-ng VM and you can use the backup to restore XCP-ng VM or perform V2V migration.
Before adding the host, you need to install a plugin on the XCP-ng host.
Then you can add the XCP-ng host with its credentials.
Backup XCP-ng VM:
After adding the XCP-ng host, you can create a backup task in 4 steps.
- Select the XCP-ng VMs you want to backup.
Restore XCP-ng VM:
When you need to restore a XCP-ng VM, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from XCP-ng backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it or instant restore to quickly recover a failed VM.
