Vinchin supports agentless backup for ZStack VM and you can use the backup to restore ZStack VM or perform V2V migration.
Before adding the host, you need to install a plugin on the ZStack host.
Then you can add the ZStack host with its credentials.
Backup ZStack VM:
After adding the ZStack host, you can create a backup task in 4 steps.
- Select the ZStack VMs you want to backup.
Restore ZStack VM:
When you need to restore a ZStack VM, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from ZStack backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it or instant restore to quickly recover a failed VM.
