Vinchin is one of the easiest solution to migrate virtual machine. You can easily migrate 15+ kinds of virtual machines according to your needs. The general process includes backing up the source VM and then directly restore it on the target host.
Supported Platform:
Vinchin currently supports V2V migration for VMware vSphere, Hyper-V, Proxmox, oVirt, OLVM, RHV, Citrix Hypervisor (XenServer), XCP-ng, ZStack, OpenStack, Sangfor HCI, H3C CAS/UIS, Huawei FusionCompute, AWS EC2, Huawei ECS, etc.
Add backup storage before creating a migration job.
You need to add both hosts to the backup system for later migration.
You can add the hosts with their credentials. Some of the virtualization platforms requires Vinchin plugin installed on them. You can refer to our HelpCenter.
Backup the source VM:
First, you need to backup the source VM in 4 steps.
- Select the VM you want to backup.
Restore the source VM to the target platform:
Then you can use the backup data to migrate the VM to target host.
- Select the created backup data
For the detailed steps, you can also refer to this video which takes VMware to Proxmox migration as an example:
