Vinchin is one of the easiest solution to migrate on-premise VM to public cloud. You can easily migrate 15+ kinds of VMs to AWS and Huawei Cloud according to your needs. The general process includes backing up the on-premise VM and then directly restore it on the public cloud.
Supported Platform:
Vinchin currently supports V2C migration for VMware vSphere, Hyper-V, Proxmox, oVirt, OLVM, RHV, Citrix Hypervisor (XenServer), XCP-ng, ZStack, OpenStack, Sangfor HCI, H3C CAS/UIS, Huawei FusionCompute, AWS EC2, Huawei ECS, etc.
Add backup storage before creating a migration job.
You need to add both platforms to the backup system for later migration.
You can add the on-premise host and the cloud platform with their credentials. Some of the virtualization platforms requires Vinchin plugin installed on them. You can refer to our HelpCenter.
Backup the on-premise VM:
First, you need to backup the source on-premise VM in 4 steps.
- Select the cloud instance you want to backup.
Restore the instance to the target public cloud:
Then you can use the backup data to migrate the on-premise VM to target public cloud.
- Select the created backup data
For the detailed steps, you can also refer to this video which takes VMware to AWS migration as an example:
