Vinchin supports agentless backup for OpenStack instance, you can use the backup to restore OpenStack Instance or perform V2V migration.
Before adding the host, you need to install a plugin on the OpenStack host.
Then you can add the OpenStack host with its credentials.
Backup OpenStack instance:
After adding the OpenStack host, you can create a backup task in 4 steps.
- Select the OpenStack instances you want to backup.
Restore OpenStack Instance:
When you need to restore an OpenStack instance, just select the restore point in the system and create a restore job in 4 steps.
- Select the restore point from OpenStack backup data
Except for full VM restore, you can also use it to perform granular restore to quickly extract file from it.
